Форум Джебел-клуба _ Suzuki RMX-250 _ Модификации Suzuki RM RMX 250 по годам
Автор: Zybex 4.10.2013, 15:01
01. Suzuki RMX 250 models from 1991. Year code: M американец
51 л.с.
АЕТС(круглый мощностной клапан)
02. Suzuki RMX 250 S models from 1992. Year code: N
Overall Length: 2,205 mm (86.8 in)
Overall Width: 885 mm (23.8 in)
Overall Height: 1,230 mm (48.4 in)
Wheelbase: 1,475 mm (58.1 in)
Dry Weight: 113 kg (249 lbs)
Engine type: Water-cooled 249 cc 1-cylinder 2-stroke. 40 hp/ 8,000 rpm, 3.8 kg-m/ 6,500 rpm.
03. Suzuki RMX 250 S models from 1993. Year code: P
Overall Width: 885 mm (34.8 in)
04. Suzuki RMX 250 R models from 1993. Year code: P
51 л.с.
05. Suzuki RMX 250 S models from 1994. Year code: R
06. Suzuki RM 250 S models from 1995. Year code: S
Overall Length: 2 167 mm (85.3 in)
Overall Width: 815 mm (32.1 in)
Overall Height: 1 250 mm (49.2 in)
Seat Height: 955 mm (37.6 in)
Ground Clearance: 360 mm (14.2 in)
Wheelbase: 1 467 mm (57.8 in)
Dry Weight: 98 kg (215 lbs)
Engine type: Water-cooled 249 cc single-cylinder 2-stroke, AETC. 51 hp (37,5 kW)/ 8,000 rpm, 47,5 Nm/ 7,000 rpm. 5-speed transmission.
07. Suzuki RMX 250 models from 1995. Year code: S американец
Overall Length: 2,185 mm (86.0 in)
Overall Width: 895 mm (35.2 in)
Overall Height: 1,245 mm (49.0 in)
Ground Clearance: 340 mm (13.4 in)
Wheelbase: 1,485 mm (58.5 in)
Dry Weight: 108 kg (238 lbs)
08. Suzuki RMX 250 S models from 1996.
рама SJ14A, двигатель J117
40 л.с. при весе 113 кг
АЕТС2(плоский мощностной клапан)
09. Suzuki RMX 250 T models from 1996.
51 л.с. вес 105 кг. рама PJ13A, двигатель J116
10. Suzuki RM 250 models from 1997. Year code: V
Seat Height: 950 mm (37.4 in)
Ground Clearance: 350 mm (13.8 in)
Wheelbase: 1,480 mm (58.3 in)
Dry Weight: 97 kg (213 lbs)
Engine type: Water-cooled 249 cc single-cylinder 2-stroke, 51 hp (37,5 kW)/ 8,000 rpm, 47,5 Nm/ 7,000 rpm. 5-speed transmission.
11. Suzuki RMX 250 S models from 1997.
40 л.с.
12. Suzuki RMX 250 models from 1997. Year code: V
Overall Length: 2,180 mm (85.8 in)
Weight: 105 kg (231 lbs)
Engine type: Water-cooled 249 cc 1-cylinder 2-stroke. 51 hp/ 8,000 rpm, 4,8 kg-m/ 6,500 rpm.
51 л.с.
13. Suzuki RM 250 models from 1998. Year code: W
Engine type: Water-cooled 249 cc single-cylinder 2-stroke, 51 hp/ 8,000 rpm, 3.8 kg-m/ 6,500 rpm.
14. Suzuki RMX 250 S models from 1998. Year code: W
40 л.с.
15. Suzuki RMX 250 W models from 1998.
51 л.с.
16. Suzuki RMX 250 R models from 1998. америка
51 л.с
17. Suzuki RMX 250 SW/SX models from 1998. австралия. европа
Выпускался в 98 и 99 годах. Поставлялся на экспорт в Австралию и Европу в 98/99/00 годах.
на мегазипе он идёт как RMX 250SW/SX - не путать с RMX 250S(T/V/W/X), который японец.
рама SJ14A, двигатель J118 - этот двигатель ничем не отличается от двигателя J116, за исключением статора - он как у модели RMX 250S(который японец), также крышка звезды другая на этом вся разница заканчивается;
мотоцикл укомплектован полным набором светотехники для использования на дорогах общего пользования - обладает очень большой и мощной фарой головного света.
51 л.с. при весе 108 кг;
18. Suzuki RM 250 models from 1999. Year code: X
Engine type: Water-cooled 249,3 cc single-cylinder 2-stroke, AETC2, piston reed. 51 hp/ 8,000 rpm, 3.8 kg-m/ 6,500 rpm.
19. Suzuki RMX 250 S models from 1999.
40 л.с.
20. Suzuki RMX 250 R models from 1999. америка
51 л.с
21. Suzuki RMX 250 SW/SX models from 1999. австралия. европа
22. Suzuki RM 250 models from 2000. Year code: Y
Engine type: Water-cooled 249 cc 1-cylinder 2-stroke. Effect, torque: ?
23. Suzuki RM 250 models from 2001. Year code: K1
Overall Height: 1,275 mm (50.2 in)
Wheelbase: 1,480 mm (58.3in)
Engine type: Water-cooled 249 cc single-cylinder 2-stroke. Effect, torque: ?
24. Suzuki RM 250 models from 2002. Year code: K2
Overall Length: 2,175 mm (85.6 in)
Overall Width: 840 mm (33.1 in)
Seat Height: 965 mm (38.0 in)
Wheelbase: 1,470 mm (57.9 in)
Dry Weight: 96 kg (211 lbs)
Engine type: Water-cooled 124.8 cc single cylinder 2-stroke.
25. Suzuki RM 250 models from 2003. Year code: K3
26. Suzuki RM 250 models from 2004. Year code: K4
Overall Height: 1,280 mm (50.4 in)
Engine type: Water-cooled 124.8 cc single cylinder 2-stroke. 55 hp (40.5 kW)/ 8,000 rpm, 50 Nm/ 7,500 rpm.
http://www.suzukicycles.org/RM-RMX-series/index.html?RM250-RMX250.shtml~isoraami
Автор: Mian 5.10.2013, 19:41
7 пункт американец
Автор: donis 5.10.2013, 20:03
7 пункт мой. Но у меня не такой бак. Фоткой выше мой бак.
Автор: Mian 5.10.2013, 20:17
Бак как на фото 7 появился в 89 и сохранился на японцах до 91, а на американцах до конца производства
Автор: Mian 5.12.2013, 11:34
Пункт 19 это 08. Suzuki RMX 250 S models from 1996 с неродными наклейками. В 99 расцветка такая же как в 98
Автор: roman-black2 5.12.2013, 11:54
у рм код года в вине находится? к примеру js1rj18cx22101489 то есть х-99г, я правильно понял?
Автор: m@x 5.12.2013, 23:32
не согласен - у меня наклейки на полносиле родные были, именно красно/чёрно/жёлтые/
кстати, они совпадают с расцветкой RM того же года
Автор: Mian 13.12.2013, 16:09
1. В микрофишах другие наклейки для 99 года
2. На этих наклейках эмблема factory effex
3. Перфорированные наклейки делаются для пластиковых баков
4. Расцветка седла и наклейки на маятнике соответствует 96 году
Автор: m@x 14.12.2013, 0:20
ты просто за все сказал,
я про свой говорил(он точно 99 г.в. и наклейки у него родные были), а тот скорее всего действительно 96 год(судя по наклейке на маятнике)
"С"-ку в 98 году перестали делать, полносил в 99(может и в 00, хотя не уверен)
Автор: Mian 15.12.2013, 14:29
Твои наклейки были не родные, на фото это видно.
Для австралийца 99г в микрофишах на мегазипе наклейки как на фото 14 и 17.
Таких наклеек какие были у тебя нет ни в одних микрофишах на RMX.
У моей Sки на маятнике стоит цифра 99.
Код S,T,V,W это не код года производства, а код модельного года. Если модель выпускалась 2 года подряд без изменений то она имела один код года. Например в 1993 продолжала выпускаться RMX250SN. Не было модели RMX250S c кодом года P, пункт 3 это RMX250SN в расцветке 0NF.
Автор: Липтон 15.12.2013, 16:48
http://photo.qip.ru/users/hrunov/96664034/132015236/
Модификация ...
Автор: m@x 16.12.2013, 6:13
я бак и боковины хорошо разглядел, наклейки были либо родные, либо переклеены в самом начале эксплуатации(но зачем???) - бак выцвел с двух сторон, строго по контору этих наклеек и под этими наклейками не было ни царапин ни потёртостей - значит либо они родные, либо переклеены не по причине повреждения родных, тогда смысл это делать?
не знаю может ты и прав, наклейки можно конечно переклеить, но зачем так заморачиваться на свежем мотоцикле?
ещё одна деталь: на моём моте, а точнее на подвеске не было этой детали 61310-27A01-000(щиток цепи) - на маятнике даже креплений не было для этого щитка, а на мегазипе в фишах есть;
также деталь 63311-44E10-000(задний подкрылок) должна крепиться к подрамнику, подрамник такой же, как на "S" - версии, а на мегазипе подрамник нарисован, как на PJ13A - как крепить этот подкрылок к такому подрамнику??? посмотри на фото п.17 там видна часть подрамника, уходящая к подкрылку, которой на мегазипе нет
может быть есть ещё фиши о которых мы не знаем, может мегазип чего напутал или я wink.gif
что касается модельного года и кода года производства - до 95 года включительно не разбирался, а вот с 96 по 99 год всё чётко прослеживается: для модели SJ14A и PJ13A - T/V/W/X - 96/97/98/99 год выпуска соответственно
Автор: Mian 16.12.2013, 7:16
На твоих наклейках так же как и на моих стоит эмблема http://www.factoryeffex.com/ то есть явно они не оригинальные. Переклеены они были за тем же зачем перешито сиденье и поменяны крылья, владельцу хотелось иметь нестандартный лучше выглядящий мотоцикл.
На мегазипе вполне могут быть ошибки, может быть есть другие микрофиши.
Но никто тут не видел мотоцикл с оригинальными наклейками и чтобы расцветка при этом такая какая у тебя была.
Автор: Сергий 1.12.2014, 14:12
Ребята помогите определить год выпуска?http://chita.moto.drom.ru/prodam-suzuki-rmx-250s-32467174.html
Автор: dymarik 1.12.2014, 15:30
А самому, что не видно wink.gif или лень смотреть.
С большой долей вероятности это:
Смотри на раму, бак, выхлоп. Вилка не от этой модели.
По любому это не 1998 год, как написано в объяве.
Автор: Zybex 1.12.2014, 16:15
А двигатель? )
Я думаю обвес с 13а, вилка от рмх 96-99
Автор: dymarik 1.12.2014, 21:02
Цитата(Zybex @ 1.12.2014, 16:15) *
А двигатель? )
Судя по отсутствию маслоподачи и патрубка помпы направленного в верх может оказаться о 51 пони.
Но навряд ли, скорее всего крышка переставлена, но все может быть.
Автор: Zybex 2.12.2014, 0:01
А посмотри еще 8ую фотку. Там сосок)
Автор: denees 2.12.2014, 8:00
Алюминиевая лапка заднего тормоза со складной носовой часть обычно стоит на полносилах. На сорокосильных - стальная.
Автор: Сергий 5.12.2014, 23:10
Ребята,всех услышал,спасибо.
Автор: Mian 6.12.2014, 22:10
Еще по глушителю видно что это 40-сильная версия
Автор: garik49rus 8.12.2014, 14:25
Резонатор крепиться как на полносиле пружинами, крышка сцепления хорошая с полносила (удобная) и прогрессия у него от полносила с тавотницами,... Так что все может быть что это 40 под 51 или 51 под 40 smile.gif
Песню вспомнил- "Я его слепила из того что было...."
Автор: Egor44 10.12.2014, 23:36
Всем доброго времени суток, почитал всё что здесь написано, но так и не понял что у меня unknw.gif в ПТС 98 год, но это явно не то, судя по всему год около 93 ,но хочется узнать точно, на подрамнике имеется наклейка
вот мне интересно кто что думает
оставил ссылку на большую картинку, вдруг кому на рабочий стол запостить))
https://leto48h.storage.yandex.net/rdisk/a9953480c4b9e8fc398d7635d48a6308/mpfs/-aAzpkMNO5pv4C7ZE5Jqfptb3-FkrTUmcMq1TQSvXgOrvFyhbb1RaAzSzQCcapIw0eulaCM_J7aStFUvTdsgUQ==?uid=0&filename=_DSC0220.jpg&disposition=inline&hash=&limit=0&content_type=image%2Fjpeg&rtoken=f6c9f906816f555240724b030e860742&rtimestamp=5488b0ed&force_default=no
Автор: Zybex 11.12.2014, 12:27
Автор: gereeng 17.12.2014, 16:33
[quote name='Mian' date='5.12.2013, 8:34' post='279276']
[/quote
ребят подскажите что за версия : номер рамы sj13a-101465 смущае вилка, отсутствие сазки,
Автор: dymarik 17.12.2014, 17:05
gereeng Извини, но ты вообще то читаешь тему. Сообщение №14
Автор: ValeroN 17.12.2014, 21:04
Год точно до 1995, вилка не родная.
Автор: Zybex 5.9.2015, 8:25
Suzuki RM250 model history 1976— Suzuki RMX250 model history 1989—
Автор: Nix 27.2.2016, 22:29
Друзья, всем привет. Помогите определилить сколько сил в данном экземпляре
Vin JS1RJ16A3P2102024
Двигатель J110
Автор: nervniy 25.3.2016, 13:55
Друзья, верно ли, что SN? по документам пишут, что 98 год, но на самом то деле похож на 93 и 94, какой точно?
Автор: Zybex 25.3.2016, 14:36
93-94
вин номер скажет 100%
Автор: nervniy 25.3.2016, 15:44
Цитата(Zybex @ 25.3.2016, 11:36) *
93-94
SJ13A102023
Автор: garik49rus 25.3.2016, 16:28
Цитата(nervniy @ 25.3.2016, 12:44) *
SJ13A102023
У японцев нет вин кодов, а модель и номер рамы. Рмх 250 sn год примерно 93, двигатель J113, 40лс, круглый клапан, вилка 43 перевертышь...
Автор: Tagirisgod 5.9.2016, 10:26
Двигатель J110
53,2 лс
Автор: Вованыч 13.1.2017, 11:01
Купил себе игрушку
рама Sj14a-
двигатель j1171
по документам 1999 г. 40лс
Смущает вилка перевертыш (от него ли) и маятник без защиты от цепи...
где посмотреть микрофиши и мануал...
Автор: TommyTech 13.1.2017, 11:06
по чем такой ?на 99 годах нет перевёртышей
Автор: ARS 13.1.2017, 14:08
130 примерно, наблюдал его на авите.
Вилку проверь штангеном, если 45-48мм, значит от кроссача, но скорей всего от предидущего мотоцикла.
Автор: TommyTech 13.1.2017, 14:20
ага, из химок. на авито за 150 стоит. не мотик с форума ? рама 98-99 год по цвету
Автор: Вованыч 14.1.2017, 0:28
из химок.... подозрения на замену вилки есть....
по каким деталям еще определить год? диаметр цилиндров разный???
Автор: Mian 15.1.2017, 17:22
Какие подозрения? Вилка 100% не родная
Автор: TommyTech 15.1.2017, 19:10
на аутору не осталось ваще мопедов )
Автор: dymarik 16.1.2017, 15:41
У меня такой же, на маятнике выбит год 99 и стоит слайдер цепи. Вилка простая, не перевёртыш.
Автор: Вованыч 17.1.2017, 0:07
вилка 45 перо и 53 труба, видно от рм какого года пока не разобрался
у меня на маятнике выбит 99/10 размер поршня на цилиндре указан 70,5 мм (по годам это значение отличается?)
Автор: домонгол 17.1.2017, 0:40
размер поршня 66,94 иэтот размер постоянен для всех годов...
Автор: dymarik 17.1.2017, 9:08
Это стандартное штатное значение,
Автор: Вованыч 17.1.2017, 12:57
Цитата(dymarik @ 17.1.2017, 9:08) *
может я неправильно перевел эту надпись??
Хочу понять откуда вилка чтобы знать от чего сальники заказывать и слайдер для щитка
Автор: ARS 17.1.2017, 13:40
Вован, ну тебе я уже написал, банально для начала штангеном диаметр пера возьми, и сообщи нам, на вид судя по копытам вилка от старого РМикса с перевертышем.
Автор: dymarik 17.1.2017, 14:43
piston stroke- ход поршня
https://motosvit.com/Suzuki%20RM_250.html
Автор: Вованыч 17.1.2017, 15:03
чуть выше писал, 45 перо и 53 труба, защита перьев имеет слайдер с направляющей... слайдер примерно такой
Автор: m@x 26.1.2017, 6:16
на маятнике посмотри, может крепления под щиток цепи спилили и зашлифовали, на "S" версии иногда так делают облегчают, что только можно - у тебя и подкрылок снят
вилка скорее всего от RM250
Автор: ARS 26.1.2017, 13:31
если от кросса, то должен быть картридж сверху пера, на моём 47мм вилка.
Автор: Вованыч 26.1.2017, 14:11
Что за катриджти как он выглядит?
Кстати вышеуказанные слайдеры (2200 шт) были напечатаны на 3д принтере - значительно дешевле.
Автор: spokoiniy 15.3.2017, 14:54
Народ, подскажите, полистав тех характеристики RMXов на семпермото заметил, что полносил повыше 40-ка сильного, где-то 935 против 895 (высота по седлу), а на каком то другом сайте указано что они все 895. Где правда?
Автор: Mian 15.3.2017, 18:36
одинаковые они
Автор: Вованыч 18.3.2017, 12:17
у кого рмх 250 96 года с перевертышем???
вот таким примерно https://www.megazip.ru/zapchasti-dlya-motocyklov/suzuki/rmx250-2356/rmx250-14070/rmx250t-e3-t-724990/front-damper-11653029
Автор: kelbas 31.3.2019, 20:01
Здравствуйте, знатаки ремыксов, подскажите не могу оприделить год №двс J111-103589 № рамыPJ11A-101414. В ДОКАХ RМХ 250S 96ГОД,
НА МЕГАЗИПЕ СТАВИШ МОДЕЛЬ ГОД НЕТ ТАГОГО.?
НА МЕГАЗИПЕ СТАВИШ МОДЕЛЬ ГОД НЕТ ТАГОГО.? если по етим фото судить то первая
Автор: m@x 17.5.2019, 10:09
это до 96 года мот
95й последний год выпуска
доки безбожно врут)
Автор: Mian 28.5.2019, 12:35
Вот номера рам PJ11A по модельным годам. Последний год 1999
K - 1989
L - 1990
N - 1992
S - 1995
T - 1996
V - 1997
W - 1998
X - 1999
Автор: Bajovod 5.2.2022, 16:37
Помогите определить год и есть ли дефицит запчастей на этот мот ?
[attachment=186402:Screenshot_20220205_163448.jpg]
