26.11.2008, 1:24
![]() Сильно заинтересован ![]() ![]() ![]() ![]() Группа: Эндуристы Сообщений: 185 Регистрация: 21.5.2008 Вставить ник Цитата Из: Москва Мотоцикл: Джебель 250ХС Honda CR250R Репутация: 2
Мучал сегодня моцик после двухнедельного стояния на холоде. Завел. Но вот что обнаружил: при откручивании газа на полную из сопла вырывается огонь, при этом мот как бы захлебывается. В чем проблема? Зажигание или карб? И как отрегулировать Мот у меня 96 года
Это пропуски зажигания. Причин может быть много. Свечку посмотреть для начала.
27.11.2008, 18:02
shurik1295, ну как успехи с пламенем? вот ответ-цитата с сайта mikuni.com:
Backfires in Exhaust Note: It is normal for many high performance exhaust systems to moderately backfire or pop when the throttle is closed from mid-to-high rpm. In fact, one should expect a well-tuned high performance engine to "pop" and "crackle" when the throttle is closed at high rpm. The popping is a result of the air/fuel mixture becoming very lean when the throttle is closed and the engine is rotating well above idle speed. It is also necessary that the exhaust system have rather open mufflers. Why This (normally) Happens: 1) When the throttle valve is in the idle position, fuel does not flow out of the main system (needle, needle jet, main jet). Fuel is only delivered to the engine by the pilot (idle) system. Other possible causes: Air Leaks: Any source of fresh air into the exhaust system can create or worsen the conditions that bring about exhaust backfiring. The most common entry point is the junction of the header pipes and mufflers. Even a small air leak can dramatically increase the intensity or likelihood of exhaust system backfiring. A high temperature silicone sealant, as can be found in many auto parts stores, may be used to seal the pipe/muffler junction. Lean Carburetion: While exhaust system popping may be considered normal, it is certainly made worse by an overly lean idle circuit. Be sure that your carburetor's pilot jet is the correct size and that the idle air mixture screw is correctly adjusted before looking for other causes of popping. The procedure for adjusting the pilot circuit is covered in the Tuning Manual. Ignition: If exhaust system popping is very loud, irregular and accompanied by loss of power, then you should suspect that the ignition system is not performing as it should. If, for some reason, the ignition sometimes fires at the wrong time, then exhaust popping can become very energetic (loud). Look for failing high tension leads (plug wires), failing ignition coil(s) and especially switches or connectors as possible causes.
27.11.2008, 18:24
То есть, если только на высоких оборотах, то это не зажигания, как я думал.
27.11.2008, 18:32
А в кратце по русски, если не сложно
27.11.2008, 18:49
27.11.2008, 20:36
Quote (parmenoff) В ссылках есть фото подобного эксперимента А где именно в ссылках? Полезно: 0
27.11.2008, 21:28
27.11.2008, 22:14
parmenoff, ок, спасибо!
Вот две ссылки оттуда, уже с русским переводом (хотя, он такой, что лучше одни картинки смотреть) Полезно: 0
Живёт здесь ![]() ![]() ![]() ![]() ![]() Группа: Свои Сообщений: 1402 Регистрация: 7.6.2010 Вставить ник Цитата Из: Екатеринбург Мотоцикл: Honda xr250 Репутация: 41
Quote (shurik1295) при откручивании газа на полную из сопла вырывается огонь, при этом мот как бы захлебывается. В чем проблема? Зажигание или карб? таже фигня появилась, только пламени нету. что делать? перебирать карб или зажигание?
Сначала попробуй свечку заменить на заведомо рабочую (новая - не сининим рабочая, много шняги), потом разбери и почисти карб. %95, что поможет.
Ребят, недавно катался на моте и хорошенько его приложил об землю вместе с собой..
очухался, встал..при попытке завести, в районе карб-воздухан сильно стрельнуло (аж оглушило), пошел синий дым(от масла что ли?!) и запахло паленой резиной(пластмассой).. вопрос: что это было? инфа: свеча НЖК 8ка, винт 2,5об, температура была около +7... Полезно: 0
SD250, обратный выброс (клапана, что вряд ли)? бедноватая для данных метеоусловий (или в результате падения) смесь? раннее зажигание (еще менее правдоподобно)? больше ничего в голову не лезет. воздухан бензом воняет, причем сильно, т.е реально. вот и шарахнуло в обратку. а вонял бенз и масло-пропитка. ИМХО канешн.
Странно что сколько раз падал такое впервые..спишу данный инцидент на случайность.
А при падениях было так еще у кого? Жень,у джебела зажигание регулируемое разве? Полезно: 0
Иногда при падениях через трубку вентиляции картера масло натекает в эйрбокс (в район после фильтра, прямо в карб почти). Может из-за этого?
Huandi, По приезду домой смотрел в айрбокс, сухо там.
..да и масло бежит когда мотик лежит с наклоном от 100 градусов и больше..у меня почти горизонтально лежал. Полезно: 0
SD250,
Миха не парся, случается такое, скорее как исключение. Женя правильно определил как обратный выброс. Причина не в ударе при падении, скоко в том что мотик положил. Первопричина вытекший бенз во впускном колекторе. Просто что бы он "стрельнул" надо что бы несколько факторов совпало. Вот тебе и "повезло" однажды. -------------------- Cogito ergo sum
Quote (SD250) у джебела зажигание регулируемое разве? не-а Quote (Wert) Миха не парся +1 Полезно: 0
Все парни, забил.
![]() Весельчак ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 640 Регистрация: 18.12.2008 Вставить ник Цитата Мотоцикл: suzuki djebl xc250 Репутация: 6
Ну че практик влип, косяк запорол,а разрулить не можешь
НЕпарься Миха, у мня пару раз так было прогазуешь прогреешь и нормалек
Quote (SD250) Все парни, забил. Нее, не пойдёт. Мопед пора тебе менять на ...новый. Этот я у тебя заберу. Не стоит заморочиваться. Я вот тоже заморачивался зимой по поводу недобора максималки(ну у нас и снега-то не было толком). Пришёл к выводу что у тебя надо забрать, ну накрайняк заказать с мегазипа, жиклеры большего номинала, как у ДРЗ-250 .
Quote (parmenoff) ну накрайняк заказать с мегазипа, жиклеры большего номинала, как у ДРЗ-250 Так закажи тюнинг-набор карба для ДРЗ. Он как раз на карб ТМ28, то есть на новые не подходит. Да и не особо дорого стоит.
Quote (parmenoff) Пришёл к выводу что у тебя надо забрать А у тм32 больше отверстия чем у тм28? В принципе, я готов избавится от старых..т.к. новые тест драйв прошли успешно.
Quote (Huandi) Он как раз на карб ТМ28, то есть на новые не подходит Игорь, я заказывал..на новый подошли. Или я тебя не понял?
Ты же заказывал какой-то странный универсальный комплект? Или еще и специальный для ТМ28? Я хочу попробовать заказать для BSR33, то есть для ATV Ямах 350-400 кубиков. Там и игла тюненая и может еще что-то, не только жиклеры.
Миха! А расход топлива не засекал?
Текстовая версия | Сейчас: 9.8.2026, 23:02 |
