4.10.2013, 15:01
01. Suzuki RMX 250 models from 1991. Year code: M американец
51 л.с. АЕТС(круглый мощностной клапан) ![]() 02. Suzuki RMX 250 S models from 1992. Year code: N Overall Length: 2,205 mm (86.8 in) Overall Width: 885 mm (23.8 in) Overall Height: 1,230 mm (48.4 in) Wheelbase: 1,475 mm (58.1 in) Dry Weight: 113 kg (249 lbs) Engine type: Water-cooled 249 cc 1-cylinder 2-stroke. 40 hp/ 8,000 rpm, 3.8 kg-m/ 6,500 rpm. АЕТС(круглый мощностной клапан) ![]() 03. Suzuki RMX 250 S models from 1993. Year code: P Overall Length: 2,205 mm (86.8 in) Overall Width: 885 mm (34.8 in) Overall Height: 1,230 mm (48.4 in) Wheelbase: 1,475 mm (58.1 in) Dry Weight: 113 kg (249 lbs) Engine type: Water-cooled 249 cc 1-cylinder 2-stroke. 40 hp/ 8,000 rpm, 3.8 kg-m/ 6,500 rpm. АЕТС(круглый мощностной клапан) ![]() 04. Suzuki RMX 250 R models from 1993. Year code: P 51 л.с. АЕТС(круглый мощностной клапан) ![]() 05. Suzuki RMX 250 S models from 1994. Year code: R Overall Length: 2,205 mm (86.8 in) Overall Width: 885 mm (34.8 in) Overall Height: 1,230 mm (48.4 in) Wheelbase: 1,475 mm (58.1 in) Dry Weight: 113 kg (249 lbs) Engine type: Water-cooled 249 cc 1-cylinder 2-stroke. 40 hp/ 8,000 rpm, 3.8 kg-m/ 6,500 rpm. АЕТС(круглый мощностной клапан) ![]() 06. Suzuki RM 250 S models from 1995. Year code: S Overall Length: 2 167 mm (85.3 in) Overall Width: 815 mm (32.1 in) Overall Height: 1 250 mm (49.2 in) Seat Height: 955 mm (37.6 in) Ground Clearance: 360 mm (14.2 in) Wheelbase: 1 467 mm (57.8 in) Dry Weight: 98 kg (215 lbs) Engine type: Water-cooled 249 cc single-cylinder 2-stroke, AETC. 51 hp (37,5 kW)/ 8,000 rpm, 47,5 Nm/ 7,000 rpm. 5-speed transmission. АЕТС(круглый мощностной клапан) ![]() 07. Suzuki RMX 250 models from 1995. Year code: S американец Overall Length: 2,185 mm (86.0 in) Overall Width: 895 mm (35.2 in) Overall Height: 1,245 mm (49.0 in) Seat Height: 955 mm (37.6 in) Ground Clearance: 340 mm (13.4 in) Wheelbase: 1,485 mm (58.5 in) Dry Weight: 108 kg (238 lbs) Engine type: Water-cooled 249 cc single-cylinder 2-stroke, AETC. 51 hp (37,5 kW)/ 8,000 rpm, 47,5 Nm/ 7,000 rpm. 5-speed transmission. АЕТС(круглый мощностной клапан) ![]() 08. Suzuki RMX 250 S models from 1996. рама SJ14A, двигатель J117 40 л.с. при весе 113 кг АЕТС2(плоский мощностной клапан) ![]() 09. Suzuki RMX 250 T models from 1996. 51 л.с. вес 105 кг. рама PJ13A, двигатель J116 АЕТС2(плоский мощностной клапан) ![]() 10. Suzuki RM 250 models from 1997. Year code: V Overall Length: 2,185 mm (86.0 in) Overall Width: 815 mm (32.1 in) Overall Height: 1,245 mm (49.0 in) Seat Height: 950 mm (37.4 in) Ground Clearance: 350 mm (13.8 in) Wheelbase: 1,480 mm (58.3 in) Dry Weight: 97 kg (213 lbs) Engine type: Water-cooled 249 cc single-cylinder 2-stroke, 51 hp (37,5 kW)/ 8,000 rpm, 47,5 Nm/ 7,000 rpm. 5-speed transmission. АЕТС2(плоский мощностной клапан) ![]() 11. Suzuki RMX 250 S models from 1997. 40 л.с. АЕТС2(плоский мощностной клапан) ![]() 12. Suzuki RMX 250 models from 1997. Year code: V Overall Length: 2,180 mm (85.8 in) Overall Width: 885 mm (34.8 in) Overall Height: 1,245 mm (49.0 in) Wheelbase: 1,485 mm (58.5 in) Weight: 105 kg (231 lbs) Engine type: Water-cooled 249 cc 1-cylinder 2-stroke. 51 hp/ 8,000 rpm, 4,8 kg-m/ 6,500 rpm. 51 л.с. АЕТС2(плоский мощностной клапан) ![]() 13. Suzuki RM 250 models from 1998. Year code: W Overall Length: 2,185 mm (86.0 in) Overall Width: 815 mm (32.1 in) Overall Height: 1,245 mm (49.0 in) Seat Height: 950 mm (37.4 in) Ground Clearance: 350 mm (13.8 in) Wheelbase: 1,480 mm (58.3 in) Dry Weight: 97 kg (213 lbs) Engine type: Water-cooled 249 cc single-cylinder 2-stroke, 51 hp/ 8,000 rpm, 3.8 kg-m/ 6,500 rpm. АЕТС2(плоский мощностной клапан) ![]() 14. Suzuki RMX 250 S models from 1998. Year code: W 40 л.с. АЕТС2(плоский мощностной клапан) ![]() 15. Suzuki RMX 250 W models from 1998. 51 л.с. АЕТС2(плоский мощностной клапан) ![]() 16. Suzuki RMX 250 R models from 1998. америка 51 л.с АЕТС(круглый мощностной клапан) ![]() 17. Suzuki RMX 250 SW/SX models from 1998. австралия. европа Выпускался в 98 и 99 годах. Поставлялся на экспорт в Австралию и Европу в 98/99/00 годах. на мегазипе он идёт как RMX 250SW/SX - не путать с RMX 250S(T/V/W/X), который японец. рама SJ14A, двигатель J118 - этот двигатель ничем не отличается от двигателя J116, за исключением статора - он как у модели RMX 250S(который японец), также крышка звезды другая на этом вся разница заканчивается; мотоцикл укомплектован полным набором светотехники для использования на дорогах общего пользования - обладает очень большой и мощной фарой головного света. 51 л.с. при весе 108 кг; АЕТС2(плоский мощностной клапан) ![]() 18. Suzuki RM 250 models from 1999. Year code: X Overall Width: 815 mm (32.1 in) Overall Height: 1,245 mm (49.0 in) Seat Height: 950 mm (37.4 in) Ground Clearance: 350 mm (13.8 in) Wheelbase: 1,480 mm (58.3 in) Dry Weight: 98 kg (215 lbs) Engine type: Water-cooled 249,3 cc single-cylinder 2-stroke, AETC2, piston reed. 51 hp/ 8,000 rpm, 3.8 kg-m/ 6,500 rpm. АЕТС2(плоский мощностной клапан) ![]() 19. Suzuki RMX 250 S models from 1999. 40 л.с. АЕТС2(плоский мощностной клапан) ![]() 20. Suzuki RMX 250 R models from 1999. америка 51 л.с АЕТС(круглый мощностной клапан) ![]() 21. Suzuki RMX 250 SW/SX models from 1999. австралия. европа Выпускался в 98 и 99 годах. Поставлялся на экспорт в Австралию и Европу в 98/99/00 годах. на мегазипе он идёт как RMX 250SW/SX - не путать с RMX 250S(T/V/W/X), который японец. рама SJ14A, двигатель J118 - этот двигатель ничем не отличается от двигателя J116, за исключением статора - он как у модели RMX 250S(который японец), также крышка звезды другая на этом вся разница заканчивается; мотоцикл укомплектован полным набором светотехники для использования на дорогах общего пользования - обладает очень большой и мощной фарой головного света. 51 л.с. при весе 108 кг; АЕТС2(плоский мощностной клапан) ![]() 22. Suzuki RM 250 models from 2000. Year code: Y Overall Length: 2,180 mm (85.8 in) Overall Width: 815 mm (32.1 in) Overall Height: 1,245 mm (49.0 in) Seat Height: 950 mm (37.4 in) Ground Clearance: 350 mm (13.8 in) Wheelbase: 1,480 mm (58.3 in) Dry Weight: 98 kg (215 lbs) Engine type: Water-cooled 249 cc 1-cylinder 2-stroke. Effect, torque: ? АЕТС2(плоский мощностной клапан) ![]() 23. Suzuki RM 250 models from 2001. Year code: K1 Overall Length: 2,180 mm (85.8 in) Overall Width: 815 mm (32.1 in) Overall Height: 1,275 mm (50.2 in) Seat Height: 950 mm (37.4 in) Ground Clearance: 350 mm (13.8 in) Wheelbase: 1,480 mm (58.3in) Dry Weight: 98 kg (215 lbs) Engine type: Water-cooled 249 cc single-cylinder 2-stroke. Effect, torque: ? АЕТС2(плоский мощностной клапан) ![]() 24. Suzuki RM 250 models from 2002. Year code: K2 Overall Length: 2,175 mm (85.6 in) Overall Width: 840 mm (33.1 in) Overall Height: 1,275 mm (50.2 in) Seat Height: 965 mm (38.0 in) Ground Clearance: 350 mm (13.8 in) Wheelbase: 1,470 mm (57.9 in) Dry Weight: 96 kg (211 lbs) Engine type: Water-cooled 124.8 cc single cylinder 2-stroke. АЕТС2(плоский мощностной клапан) ![]() 25. Suzuki RM 250 models from 2003. Year code: K3 Overall Length: 2,175 mm (85.6 in) Overall Width: 840 mm (33.1 in) Overall Height: 1,275 mm (50.2 in) Seat Height: 965 mm (38.0 in) Ground Clearance: 350 mm (13.8 in) Wheelbase: 1,470 mm (57.9 in) Dry Weight: 96 kg (211 lbs) Engine type: Water-cooled 124.8 cc single cylinder 2-stroke. АЕТС2(плоский мощностной клапан) ![]() 26. Suzuki RM 250 models from 2004. Year code: K4 Overall Length: 2,175 mm (85.6 in) Overall Width: 840 mm (33.1 in) Overall Height: 1,280 mm (50.4 in) Seat Height: 950 mm (37.4 in) Ground Clearance: 350 mm (13.8 in) Wheelbase: 1,470 mm (57.9 in) Dry Weight: 96 kg (211 lbs) Engine type: Water-cooled 124.8 cc single cylinder 2-stroke. 55 hp (40.5 kW)/ 8,000 rpm, 50 Nm/ 7,500 rpm. АЕТС2(плоский мощностной клапан) ![]() http://www.suzukicycles.org/RM-RMX-series/....shtml~isoraami Полезно:
Zybex Модификации Suzuki RM RMX 250 по годам 4.10.2013, 15:01
Mian 7 пункт американец 5.10.2013, 19:41
donis 7 пункт мой. Но у меня не такой бак. Фоткой выше м... 5.10.2013, 20:03
Mian Бак как на фото 7 появился в 89 и сохранился на яп... 5.10.2013, 20:17
Mian Пункт 19 это 08. Suzuki RMX 250 S models from 1996... 5.12.2013, 11:34
m@x Цитата(Mian @ 5.12.2013, 13:34) В 99 расц... 5.12.2013, 23:32
gereeng [quote name='Mian' date='5.12.2013, 8:... 17.12.2014, 16:33
roman-black2 у рм код года в вине находится? к примеру js1rj18c... 5.12.2013, 11:54
Mian 1. В микрофишах другие наклейки для 99 года
2. На ... 13.12.2013, 16:09
m@x ты просто за все сказал,
я про свой говорил(он то... 14.12.2013, 0:20
Mian Твои наклейки были не родные, на фото это видно.
... 15.12.2013, 14:29
m@x Цитата(Mian @ 15.12.2013, 16:29) Твои нак... 16.12.2013, 6:13
Mian Цитата(m@x @ 16.12.2013, 9:13) я бак и бо... 16.12.2013, 7:16
Липтон Модификация ... 15.12.2013, 16:48
Сергий Ребята помогите определить год выпуска?http://chit... 1.12.2014, 14:12
dymarik Цитата(Сергий @ 1.12.2014, 14:12) Ребята ... 1.12.2014, 15:30
Zybex Цитата(dymarik @ 1.12.2014, 15:30) А само... 1.12.2014, 16:15
dymarik Цитата(Zybex @ 1.12.2014, 16:15) А двигат... 1.12.2014, 21:02
Zybex Цитата(dymarik @ 1.12.2014, 21:02) Судя п... 2.12.2014, 0:01
denees Алюминиевая лапка заднего тормоза со складной носо... 2.12.2014, 8:00
Сергий Ребята,всех услышал,спасибо. 5.12.2014, 23:10
Mian Еще по глушителю видно что это 40-сильная версия 6.12.2014, 22:10
garik49rus Цитата(Mian @ 6.12.2014, 19:10) Еще по гл... 8.12.2014, 14:25
Egor44 Всем доброго времени суток, почитал всё что здесь ... 10.12.2014, 23:36
Zybex RE: Модификации Suzuki RM RMX 250 по годам 11.12.2014, 12:27
dymarik gereeng Извини, но ты вообще то читаешь тему. Соо... 17.12.2014, 17:05
ValeroN Год точно до 1995, вилка не родная. 17.12.2014, 21:04
Zybex Suzuki RM250 model history 1976— Suzuki RMX250 mod... 5.9.2015, 8:25
Nix Друзья, всем привет. Помогите определилить сколько... 27.2.2016, 22:29
Tagirisgod Цитата(Nix @ 27.2.2016, 19:29) Друзья, вс... 5.9.2016, 10:26
nervniy Друзья, верно ли, что SN? по документам пишут, что... 25.3.2016, 13:55
Zybex Цитата(nervniy @ 25.3.2016, 13:55)
Друзь... 25.3.2016, 14:36
nervniy Цитата(Zybex @ 25.3.2016, 11:36) 93-94
ви... 25.3.2016, 15:44
garik49rus Цитата(nervniy @ 25.3.2016, 12:44) SJ13A1... 25.3.2016, 16:28
Вованыч Купил себе игрушку
рама Sj14a-
двигатель j1171
по... 13.1.2017, 11:01
TommyTech по чем такой ?на 99 годах нет перевёртышей 13.1.2017, 11:06
ARS 130 примерно, наблюдал его на авите.
Вилку проверь... 13.1.2017, 14:08
TommyTech ага, из химок. на авито за 150 стоит. не мотик с ... 13.1.2017, 14:20
Вованыч из химок.... подозрения на замену вилки есть....
... 14.1.2017, 0:28
Mian Цитата(Вованыч @ 14.1.2017, 2:28) .... по... 15.1.2017, 17:22
TommyTech на аутору не осталось ваще мопедов ) 15.1.2017, 19:10
dymarik У меня такой же, на маятнике выбит год 99 и стоит ... 16.1.2017, 15:41
Вованыч Цитата(Mian @ 15.1.2017, 17:22) Какие под... 17.1.2017, 0:07
домонгол Цитата(Вованыч @ 17.1.2017, 0:07) вилка 4... 17.1.2017, 0:40
dymarik Цитата(домонгол @ 17.1.2017, 0:40) размер... 17.1.2017, 9:08
Вованыч Цитата(dymarik @ 17.1.2017, 9:08) Может у... 17.1.2017, 12:57
ARS Цитата(Вованыч @ 17.1.2017, 12:57) может ... 17.1.2017, 13:40
Вованыч Цитата(ARS @ 17.1.2017, 13:40) Вован, ну ... 17.1.2017, 15:03
dymarik piston stroke- ход поршня
https://motosvit.com/Su... 17.1.2017, 14:43
m@x на маятнике посмотри, может крепления под щиток це... 26.1.2017, 6:16
ARS Цитата(m@x @ 26.1.2017, 6:16) на маятнике... 26.1.2017, 13:31
Вованыч Что за катриджти как он выглядит?
Кстати вышеуказ... 26.1.2017, 14:11
spokoiniy Народ, подскажите, полистав тех характеристики RMX... 15.3.2017, 14:54
Mian одинаковые они 15.3.2017, 18:36
Вованыч у кого рмх 250 96 года с перевертышем???
вот таки... 18.3.2017, 12:17
kelbas Здравствуйте, знатаки ремыксов, подскажите не могу... 31.3.2019, 20:01
m@x это до 96 года мот
95й последний год выпуска
доки ... 17.5.2019, 10:09
Mian Вот номера рам PJ11A по модельным годам. Последний... 28.5.2019, 12:35
Bajovod Помогите определить год и есть ли дефицит запчасте... 5.2.2022, 16:37![]() ![]() |
Текстовая версия | Сейчас: 6.8.2026, 11:32 |
